Scatter object with dynamics
mikeadamwood
I'm using the scatter object as I want to use the random colour node to have varying different colours sampled from a gradient.
I have applied a rigid body dynamics tag to this scatter object so the spheres fall to the floor, I assumed it would work just like the cloner where if you pause it stops and freezes the frame...However with the scatter object if I press pause it snaps back to frame 0's position.
Any way of fixing this or a way of getting the random colour shader to work with a standard cloner?
Also would be really nice if you could do random colour on a per object basis without using the scatter object, when you manually copy object it is always the same colour
Windows 11 Pro | ASUS Pro WSX80E | AMD Threadripper Pro 5975WX 32-Core | 256GB Micron 8x32GB 3200MHz ECC | 2x PNY RTX6000 ADA
It's not implemented for that. You would be lucky if that would work.
