Problem with OctaneDB
BorderLine
Hi Juan,
I've a problem with OctaneDB materials. If i trying to load Beton 03/misc, OctaneDB block and nothing happen ! I can save my scene but OctaneDB windows is blocked !
juanjgon
I know that there is a bug in the Octane API LiveDB feature in these latest builds that is fixed now for the next build. Probably your problem is related to this issue.
As a workaround, If you need this material you could install an older plugin version to get it.
BorderLine
Thanks Juan,
I'm going to do other.
BorderLine
Hi Jaun,
Do you have any idea when we're going to have a new version?
It's really annoying not to be able to use Octane textures.
I switched back to the previous version, but I had a problem with the scenes recorded with the new version.
The scene opens but the Octane plugin does not activate and the "Enable plugin" button does nothing
So I keep this new version and I wait for the update.
Do not forget the light sphere please, i prefere sphere light rather than the emitting surface because I often need to illuminate with the diffusion of the sphere but without seeing the emitter.
Thank in advance
Franck
juanjgon
I was waiting for the final 3.05 API version (the one with the updated rounded edges feature) that should be available this week, but I can post a custom build to solve this problem. Are you working with LW2015 in windows, right?
BorderLine
Yes, but I don't want to bother you! I will wait.
Thank Juan
juanjgon
Test the new build released today to see if the problem is fixed.
Return to “Lightwave 3D”
