OctaneRender® for Maya® 3.04.5 - 9.8 Win [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Versions 2015, 2016, 2016.5 and 2017 64-bit on MS Windows operating systems.
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of OctaneRender™ Standalone on your machine.
  • Fixed multimaterial crash in cases when some material gets deleted.
  • Minor fixes and improvements...
Known issues:
- batch rendering on OSX is not working currently. This is Octane engine related issue, will be fixed in next SDK.
- Octane SDK 3.04.5 may crash sometimes when using LiveDB. Should be fixed with next SDK version.
DOWNLOAD
OctaneRender for Maya 3.04.5 - 9.8
OctaneRender for Maya DEMO 3.04.5 - 9.8
viewtopic.php?f=24&t=57660
Yours,
The OctaneRender™ Team.
Jolbertoquini
Hi Guys,
Any news about export issues? for other stuff is correct but still missing this main fixes for export.
JO
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
Jolbertoquini
Hi Jim,
Also I find a issue with the scale on Fluid (and other scales options) . If my scene in additional tab "the scale" are set "1" is fine I get really good results now if I change my scene size to 0.01 based on "cm" on Maya scale (Pretty standard in the industry!) I have weird results all scales doesn't work so well in the volume node, scatter node, displacement and etc... The scale option are not translate when this settings are changed , The render they are never the same, I specting changes but not a huge change specially on the fluids.
For me I have a scene with any fluid set with a size of 2 meters they are really hard to make work aswell look the same. I will attach a scene here Please takea look if you don't mind.
Just change the main scale "1 to 0.01" and you will see the problem then try to match the result is really hard to get the same look. The correct I think if I multiply the value by 10 should show the same result isn't?, please some help would be great.
Best,
Jo
Fluid_issues.rar
Maya scene
(12.68 KiB) Downloaded 283 times
nedan
Thanks for the update.
Strange is that I found a problem, trying to test a simple scene, with a simple poly plane with Octane diffuse material, a sphere with octaneGlossyMaterial and a octaneSunSky with Day light env.
On both of diffuse passes, very hight level of noise, even that the beauty looks fine at lower samples, less than 60, for the diffuse pass needs more that 600 to look clean. This was not happened on v2.
calus
nedan wrote:Thanks for the update.
With what Kernel ?
Do you have the same result in Standalone 3.04.5 ? (exporting your scene as ORBX)
Pascal ANDRE
nedan
I am using 3.04.5 on Maya 2017. Here is the test scene:
https://we.tl/6KsEYqO2xC
calus
@nedan,
was asking your kernel (path tracing) ;)
ok so I have the same result as you, in Maya2016 and also in Standalone 3.05
but the DiffuseIndirect is different in standalone 2.26.1
I remember now, this is because in V3 we're supposed to multiply raw passes with filter passes.
So to get the same DiffuseIndirect pass as in V2, you have to multiply the raw DiffuseIndirect with the the Diffusefilter pass.
Or you can just disable the RAW toggle to get directly the same passes as in V2 :D
Pascal ANDRE
Vrr
Seems to be a problem with Livedb in Maya 2017, when importing Octane mat Maya Freezes or Crash :cry: would be great if this can be fixed.
Jolbertoquini
Hi Jim,
I was trying to bake textures but is missing the baking ID options also UV set options, "on the Octane options at the mesh" with the layer ID.
Is that other location for that? I'm confused?
Best,
JO
