Displacement offset not working! [ SOLVED ]
mickyboys
The offset does not seams to work at all since I changed tom V3.
In V2 it worked just fine.
Can someone confirm that?
KR,
Axel
calus
Right, I confirm.
In fact since V3, Octane Core doesn't have an offset attribute in the displacement node.
It has been replaced by a mid level attribute. (working differently)
But JimStar aparently forgot to update the displacement node in the plugin.
Pascal ANDRE
BK
Hi mickyboys,
`The offset does not seams to work at all since I changed tom V3.
In V2 it worked just fine.`
The issue has already been fixed yesterday. :)
Kind Regards
bk3d
mickyboys
What do you mean by its being solved already? Where can I find it?
BK
hey mickyboys, :)
You can find offset in OctaneDisplacementNode. Here's a screenshot :
Kind Regards
bk3d
mickyboys
hey mickyboys, :)
There seems to be a miss-understanding.
I know where it is and what is should do, but is does not!
Therefore, I reported that the offset does not work at all.
So, my question, do you have a solution?
calus
BK wrote: You can find offset in OctaneDisplacementNode. Here's a screenshot :
Hey Bikram this issue is not solved,
As I already explained in the tread,
the offset attribute doesn't work because OctaneV3 Core doesn't have an offset attribute anymore in the displacement node.
And JimStar forgot to update the displacement node in the plugin with the new mid level attribute.
Pascal ANDRE
calus
mickyboys wrote: So, my question, do you have a solution?
Use standalone ;)
Pascal ANDRE
mickyboys
OK, get you there.
Is someone working on that update -?
I cannot start to move geometry based on individual heights of the displacement.
KR,
calus
mickyboys wrote: Is someone working on that update -?
Oh ok I understand now why Bikram was confused ,
indeed JimStar already updated the displacement node but he did it completely wrong :D
the Mid-level attribute is supposed to replace the Offset attribute not the Level of detail.
Anyway, the displacement node is still broken.
Pascal ANDRE
Return to “Autodesk Maya”
