Maya® Version Requirements
This release will work with Maya® Version 2017 64-bit on OSX operating systems (including and above 10.9).
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of OctaneRender™ Standalone on your machine.
- Imporved a virtual material consistency when rendered on different machines. This will work OK only in Maya versions starting from 2016, 'cause it uses some new functionality of it (the scenes must be saved from these versions too).
- Just run the autoinstaller file.
DOWNLOAD
OctaneRender for Maya - 9.7 OSX
OctaneRender for Maya DEMO - 9.7 OSX
viewtopic.php?f=24&t=57660
Yours,
The OctaneRender™ Team.
