OctaneRender® for Maya® 3.04.5 - 9.7 OSX [OBSOLETE]
Moderator: JimStar
JimStar
Otoy® is proud to announce the availability of a new version of OctaneRender™ for Maya®
Maya® Version Requirements
This release will work with Maya® Version 2017 64-bit on OSX operating systems (including and above 10.9).
To run OctaneRender™ for Maya®, you need to also have an activated OctaneRender™ Standalone copy activated on the machine you wish to install the plugin onto.
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of OctaneRender™ Standalone on your machine.
CHANGES SINCE THE PREVIOUS VERSION
  • Imporved a virtual material consistency when rendered on different machines. This will work OK only in Maya versions starting from 2016, 'cause it uses some new functionality of it (the scenes must be saved from these versions too).
Installation:
- Just run the autoinstaller file.
DOWNLOAD
OctaneRender for Maya - 9.7 OSX
OctaneRender for Maya DEMO - 9.7 OSX
For network slave and daemon please download standalone installer here:
viewtopic.php?f=24&t=57660
Yours,
The OctaneRender™ Team.
diaa3d
Hi Jim
its working great but the batch render doesn't work i thought the problem was with my scene so i tried a simple scene with cube rotating but it still doesn't batch render!!
i am using maya 2017
Return to “Releases”
