so as in the topic: What are the differences between Cosine mix, and normal mix node in Octane render?
Thanks !
Luke
Mix and cosine mix differences?
// Behance: https://www.behance.net/LukaszKondek //
- Octane v3
- 1x Geforce 980 Ti , and 1x 570 GTX
- Octane v3
I think it gives non-linear mix in values 0-Pi ( amount 0-100%) and intuitive non-linear control behaviour:
Amount 0%: tex1=100% tex2=0% ( as in linear )
Amount 50%: tex1=50% tex2=50% ( as in linear )
Amount 100%: tex1=0% tex2=100% ( as in linear )
But all between those states is non-linear as cos(x) gives. That is the point I think.
https://www.google.pl/search?q=cos(x)+w ... FguOgOM%3A
Be patient for me, please. I am new here.
Thanks Man, although i understand nothing of it : D
Cheers
Luke
Cheers
Luke
- Octane v3
- Octane v3
look at the graph.
Cosine Mix is like balance between Left & Right but non-linear. Mix Tex is linear.
But Mix tex & Cosine Mix has 3 common points of control.
If you want to have 100% Left output for 0 Amount, 50% Left&Right in the middle and 100% Right output for Amount 1.0
both of mixer gives you that even if one of them is linear and second non-linear.
You can say that if you balance from Left to Middle value of slider then in Mix Tex output value changes quicker and in linear way against to Cosine Mix that changes output value slower at the beginning.
