OctaneRender® for Maya® 2.26.1 - 7.20.5 Win [LAST 2.X]
Maya® Version Requirements
This release will work with Maya® Versions 2015, 2016, 2016.5 and 2017 64-bit on MS Windows operating systems.
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of OctaneRender™ Standalone on your machine.
  • Fixed a particle system export bug.
  • Fixed a particle system crash.
DOWNLOAD
OctaneRender for Maya 2.26.1 - 7.20.5
viewtopic.php?f=24&t=57368
Yours,
The OctaneRender™ Team.
Jolbertoquini
Niceee.... Thanks, Jim.
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
QuinceHungaryKft
much appreciated, thanks!
solomon
Hi Jim,
I need some help, how do I active the plugin version in Maya 2017 and Maya 2016 Ext 2?
I tried to enter my octane live 2.x userid and password but those are not working.
and yet in Maya 2014, Octane is working fine, and even the standalone works fine without asking to be activated
Solomon W. Jagwe
calus
solomon wrote:Hi Jim,
For all V2 plugin, activation should be the same,
maybe it's not working because you have standalone open at the same time ?
Pascal ANDRE
solomon
Standalone is closed
Solomon W. Jagwe
solomon
It's finally working now ~ I had to enter the numeric live ID first, and the password (typed not copy and paste) and then click activate... I get the error, and then I click in the numeric ID and delete and replace it with my account name.. then click activate... and that worked both for Maya 2016 Ext 2 and Maya 2017.... still a strange way to activate though...
Solomon W. Jagwe
renmaxhb
JimStar,
Thanks your works,but I need DEMOVISION,please Releases DEMOVISION every time ;)
SimonPercy
Am I correct that the Zdepth pass is still not working?
If it isn't, then how can you call this "production ready"?
Darkside Studios London
Feature Film & TV Visual Effects and Animation
14 Grays Inn Road, London, United Kingdom
http://www.darksidestudios.uk
calus
SimonPercy wrote:Am I correct that the Zdepth pass is still not working?
zdepth pass works, in V2 you have to enable the "tonemapping" option in pass settings to see it easily in IPR.
Pascal ANDRE
Locked
