"Export selection" doesn't work [SOLVED]
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
calus
File / export selection / "octaneRender scene" or "octaneRender animated scene" behave the exact same way as File / export all /
The whole scene is exported despite the fact that I choose to export only selection.
Pascal ANDRE
calus
So this issue is still not solved in OctaneRender® for Maya® 3.05.3 - 9.38,
and that's a shame because having to export all the scene instead of selection is really a workflow breaker when we have to update often only some part of a Standalone scene.
Lot of time lost and lot more of possible errors because of that.
In the meantime I have a good workaround for this issue :
I create a temporary Maya render Layer based on my selection, export the ORBX, delete the render layer.
But still I have to add a camera to the render layer to make the export work while I don't want a camera or a render target in my ORBX, I already have that in my Standalone scene... :(
If it's not a SDK limitation we should not be forced to export a render target...
Also if I can do this by hand why the plugin can't do automatically the same thing under-the-hood ?
create a temporary render layer based on selection > export to ORBX > remove the temporary Maya render layer
Pascal ANDRE
cakeller98
A. Win 7
B. Quadro M5000M
C. System RAM 32GB
D. Nvidia driver version 376.33
E. OctaneRender Standalone version, 3.05
F. OctaneRender for Maya 3.05.3-9.41 (same problem in 9.3?)
G. Autodesk Maya 2017 Update 3
create a poly-sphere
assign a blinn shader to it
adjust some parameters so that it has some transparency and should translate to some type of transparent octane shader
adjust ior to 1.5 or anything not 0 or 1.0.
click button to convert maya shaders to octane.
test in octane for maya that everything looks as expected.
select sphere, and click file->export selected [] (click the options box) then select any of the octane export modes and then click save.
//EXPORT SELECTED FAILS ON (animated scene and alembic)
file -force -options "alembicWrap=1;" -typ "OctaneRender animated scene" -pr -es "C:/Users/Christopher/Desktop/asdf_animscene.orbx";
// Error: line 0: Could not save file "C:/Users/Christopher/Desktop/asdf_animscene.orbx". //
file -force -options "" -typ "OctaneRender alembic" -pr -es "C:/Users/Christopher/Desktop/asdf_alembic.abc";
// Error: line 0: Could not save file "C:/Users/Christopher/Desktop/asdf_alembic.abc". //
//EXPORT ALL FAILS ON (animated scene and alembic)
file -force -options "alembicWrap=1;" -type "OctaneRender animated scene" -pr -ea "C:/Users/Christopher/Desktop/exportall_anim_scene.orbx";
// Error: line 0: Could not save file "C:/Users/Christopher/Desktop/exportall_anim_scene.orbx". //
file -force -options "" -type "OctaneRender alembic" -pr -ea "C:/Users/Christopher/Desktop/exportall_alembic.abc";
// Error: line 0: Could not save file "C:/Users/Christopher/Desktop/exportall_alembic.abc". //
//EXPORT ALL and SELECTED SUCCEEDS but exports the whole scene including render targets and etc.
//export selected
file -force -options "" -typ "OctaneRender scene" -pr -es "C:/Users/Christopher/Desktop/asdf_static_scene.orbx";
// Result: C:/Users/Christopher/Desktop/asdf_static_scene.orbx //
//export all
file -force -options "" -type "OctaneRender scene" -pr -ea "C:/Users/Christopher/Desktop/exportall_scene.orbx";
// Result: C:/Users/Christopher/Desktop/exportall_scene.orbx //
As of 2019-02-12
- Dell Precision 7710 w/Xeon E3-1535M v5 2.9GHz
- Windows 7 Pro, 64-bit (SP 1)
- 32 GB System Memory
- nVidia Quadro M5000M (Driver Ver 416.78)
- Standalone 4.0, 4.01.1, 4.02
- Maya 2018, 2019
Modo 12
Sketchup 2018, 2019
calus
Solved in OctaneRender® for Maya® 3.06 (test 3) - 10.1
Export selection have been implemented :)
Pascal ANDRE
Return to “Bug Reports”
