"Time Limit(sec)" should override "Max. samples"
Hello, not sure what you are asking!!!
Time limit is working as I supposed that works. What's the problem or question? Give more solid info to let me understand it!
When I set a "Time Limit" Octane renders for that time (eG 5 min). Thats fine. BUT: If "max samples" are low, for eG 124 samples, octane stops rendering at 124 samples. Does not render for 5 min
I have first set the samples verry high, so that octane renders for the "Time Limit" i was giving it.
sorry if i wasn't that clear
Yes you have to do it for now, not hard I believe. Somethings may look easy from outside but not internally sometimes. Just noted your request...moebius wrote:When I set a "Time Limit" Octane renders for that time (eG 5 min). Thats fine. BUT: If "max samples" are low, for eG 124 samples, octane stops rendering at 124 samples. Does not render for 5 min
