OctaneRender™ Standalone 3.04.3
abstrax
Hi all,
Apologies for the noise, but unfortunately 3.04.2 introduced one major regression, which we really wanted to have fixed.
Changes since version 3.04.2:
  • Volume emitters are now included in the emitter pass and light passes.
  • Swapped the order of the frame and render pass placeholders in the default file name template of the batch render script and job graph (see viewtopic.php?p=293556#p293556).
  • Fixed broken update of object layer data when one object layer node is modified.
  • Fixed broken smooth flag in mix materials, i.e. if all children of a mix material have the smooth option disabled, the mix material will be rendered non-smooth, too (see viewtopic.php?p=293395#p293395).
  • Fixed the inverted behaviour of the "use priority" option of the render device dialog.
License tracking change since version 3.02
To implement the floating licensing system we need to keep track of all Octane processes that use a specific license on the computer. This way we only release/deactivate a license when no Octane process is using that license anymore. Originally we used a third-party library for that. Unfortunately there were various issues with that and caused crashes during startup in various circumstances. To fix the problem we changed it to an internal (file based) system in version 3.02. Unfortunately this separates the license usage tracking of version 3.02 and higher from the usage tracking of 3.00, 3.01 and 3.01.1.
-> Please make sure that you only run either version 3.00, 3.01 and 3.01.1 at the same time or only version 3.02 or higher.
Pascal GPU support
This build is done using the CUDA 7.5 and 8.0 toolkits. NVIDIA is still looking into various CUDA issues and we haven't done any further Pascal specific optimizations yet, but from what we can tell, the Pascal GPUs seem to run fine so far.
OctaneRender Standalone downloads
Windows
- 64-bit commercial version (installer)
- 64-bit commercial version (ZIP archive)
- 64-bit demo version (installer)
- 64-bit demo version (ZIP archive)
Mac OS X
- 64-bit commercial version (DMG image)
- 64-bit demo version (DMG image)
Linux
Photoshop workflow plugin download
You can download and install the plugin either via the Adobe Exchange platform or you can download it from the link below and manually install it.
Windows and Mac OS X
- Photoshop extension (v1.0.3) (ZXP archive)
Happy rendering,
Your OTOY NZ Team
calus
abstrax wrote: Swapped the order of the frame and render pass placeholders in the default file name template of the batch render script and job graph (see viewtopic.php?p=293556#p293556).
Thanks !
Pascal ANDRE
Elvissuperstar007
pay attention to the integration of 3ds max
we do not work Particle viewtopic.php?f=27&t=56380 it promised to fix a long time! I can not complete projects
standard camera is not working ( black screen ) Give us an opportunity to render through the dynamic viewport animations. 3d max framebuffer constantly buggy
sequentia does not work it's just a glitch of the world!
I would Standalone exported, but the animation file weighs 80 GB ))
in other integrations have stable release of 3.0, we do not have this))) even take and sets 2.0 ))) jokers
gah5118
still hoping to see a master render job node for easier automated batch rendering.
Windows 8.1 | i7 950 | GTX 780ti | 24gb ddr3
abstrax
Elvissuperstar007 wrote:pay attention to the integration of 3ds max
We are working on it. Christophe just took over the 3ds max plugin a couple of months ago and is working as fast as he can.
abstrax
gah5118 wrote:still hoping to see a master render job node for easier automated batch rendering.
We are working on it, but it's not finished yet.
gah5118
awesome! Can't wait to see where it goes but, will have to.
abstrax
Please check this discussion viewtopic.php?f=9&t=57135
Goldisart
no work sync frames to particle Age
Jolbertoquini
We need maya Plug pleaseeeeee! The alpha is not working at All we can't activate and when we install the the plug for 3 we loose the plug for 2 and also we can open any older scenes and no shaders options just pointless the alpha right now on Maya.
Any one extra as developer to help on Maya????
Regards,
JO
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
