showing incomplete material window
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
rodrigotrovao
Every new Octane Render for max, at least my material windows shows like these:
octanes material window
As you may see, incomplete. If i change to mental ray, it comes in full width size. Everything is readable.
mental rays material window
Could you guys FIX it?
Im using this version:
octane render Version
And could you guys insert this help tip, for example, as a "live help" on mouse over each button?
Anyway, thanks a lot
oh, by the way, Im using max 2017 , with 3840 x 2160 resolution.
paride4331
Hi rodrigotrovao,
3dsMax 2017 natively supports 4k monitor. The issue you report was previously verified.
It would depend on the new UI 3dsMax and It will be fixed in the next update.
A temporary workaround is to set the screen resolution to 2k.
Regards
Return to “Bug Reports”
