Cinema 4D Animated orbx export
artech7
Hello all,
I'm wondering if any of you can provide an answer for me regarding this issue I am running into.
I can provide console information and logs if needed. If they are, I will provide them when I am able later tonight.
So, the issue I am running into is exporting an Animated orbx file from Cinema 4D. When in the live viewer, on frame 1, I go to file and export using the Animated option. Everything exports just fine, except for the clouds I am using. I am using a vdb file generated in Houdini. The clouds are simply just not showing. However, when I use a regular .ocs file, everything is there, but then I can't render out the animation.
Do I just need to find the node that stores the vdb file and reimport it into Octane Stand alone, after exporting it from C4D? Or, is there a different reason?
Any help and explanation on this would be fantastic.
Thank you!
2x Titan Z
1 Geforce 710 (For Displaying to the monitor)
AMD 8350 CPU
32GB Ram
(Will be using the most up to date versions available. Always)
Octane 3
Octane Plugin for C4D R15
Octane Plugin for Houdini 15
https://www.pwndesign.com/
i don't know what's your version! But plugin needs more work and revisions to be %100 perfect for export. Volumes will not be exported fine until getting a new update.
artech7
Ah, sorry for not stating the versions. I'm having a hard time finding the Signature options in the account settings for the forums, otherwise, I would just put it there.
I'm using the latest 3.0 release for both Octane Stand Alone and the Plugin. So that's 3.04 for Standalone and 3.03.3 - R1 for Cinema 4D.
2x Titan Z
AMD 8350 CPU
32GB Ram
Octane 3
Hi artech7,
the latest plugin version is 3.04-R1, just like the Standalone.
You can always find the latest version in the first post of the first discussion of this forum section:
viewforum.php?f=85
and here is the direct link:
viewtopic.php?f=85&t=56929
artech7
bepeg4d wrote:Hi artech7,
viewforum.php?f=85
I have the latest standalone and plugin versions available on the forum. Using C4D R17. I updated my signature to reflect that.
In any case, I'll try exporting it again later today. Turns out, that I couldn't get anything to work inside of C4D until after I had tagged the Octane Volume with an Octane Object Tag. So maybe I have to that when I export it as an animated orbx file.
I understand that I shouldn't have to do that, but that is the only way that I managed to get it to work.
2x Titan Z
AMD 8350 CPU
32GB Ram
Octane 3
Simply don't export scenes when you have volume objects. It will not work and i need to revise some parts of plugin to make it's working.
artech7
aoktar wrote:Simply don't export scenes when you have volume objects. It will not work and i need to revise some parts of plugin to make it's working.
Yeah, no biggie. I just wasn't sure if that was a normal thing or not or if you guys were already aware that it wasn't working. I just figured I would post about it, just in case.
2x Titan Z
AMD 8350 CPU
32GB Ram
Octane 3
