what does this error message mean?
lightboy
Unexpected response format:
I'm starting to get this error on some scenes that used to be ok now I get this message and a short while later the rendering fails usually but not always.
I'm not getting this in the LW version on octane just in modo.
any ideas?
Windows 10 | 1950x threadripper |64gb Ram | EVGA GTX1080 ti x3 |
Modo 13 64bit
Lightwave 2018
Nvidia driver 419.67
Octane modo plugin version 4.04.0.145
Octane lightwave plugin version 4.04
I think that is a Network Render warning, but I will check with Otoy to be sure. The plugins have different settings, so try setting the Modo plugin Network Render settings to be the same as what you have for the Lightwave plugin.
lightboy
Hi Paul
Both settings for network are the same in the lw plugin and the modo plugin.
also I'm not network rendering, just the default install.
I'm also getting some gpu crashes now but it seems scenes that I get that message are more likely to have a gpu crash.
I will do some more testing to see if I can track down what is causing the error message.
As a test I uninstalled the plugin and went back to version 2, I then rendered the same scene and no error messages and so far no gpu crashes.
I have noticed that octane version 3 does not seem to be as stable as version 2 was.
Modo 13 64bit
Lightwave 2018
Thanks. I have asked Otoy to take a look - as it's an error coming from the Octane API, not the plugin.
mojave
@lightboy
This is not network related but we need to gather a bit more information to make sure what's going on so I have just sent you a PM with instructions to further investigate this issue.
Return to “Foundry Modo”
