Blue screen of death help
radiant
Hello guys, fir the past 5 weeks I have had multiple blue screen of deaths, it happens every three hours or so. I have recently updated my drivers and such so I don't know why it is still happening.
Here is some more info every time it happens this is what I et, i redirected it
Page fault in non paged area
Driver irol not less or equal
Iriol not less or equal
Memory management
Dfn list corrupt
And many others,
I'm suspecting it is a hardware issue but if it is where do I look at and if it software then where do i look at?. It's the fastest rig in adeliade at the moment yet it is crashing every hour
I'm typing this on my iPad at the moment so excuse the spelling mistakes
Cheers
Radiant
Win8 Pro 64bit ULT|Intel Core i7 3930K|3.20 GHz|32 GB RAM|GTX 590|UD5 2011 socket||2x TB HD||Master Cooler HAF X||Blender 2.6||Maya 2012||Octane|
abstrax
radiant wrote:Hello guys, fir the past 5 weeks I have had multiple blue screen of deaths, it happens every three hours or so. I have recently updated my drivers and such so I don't know why it is still happening.
Memory management
Dfn list corrupt
And many others,
Cheers
Radiant
Try looking at your memory first: If you have more than one RAM module, remove one and leave the rest in. And test, if the problem still occurs, put the module back and remove another one. And so on.
Another problem could be overheating: Open the case of your computer and see if it improves things.
Marcus
Skeletor
With a badass computer like yours I wouldn't be surprised if it get too hot inside the case as Abstrax mentions.
Win 7 64bit, GF 460 2GB, Intel quad, 4GB memory
radiance
If swapping the ram won't work, it will likely be a busted motherboard...
Maybe try booting a small usb stick Linux distribution and running some tests, when a linux kernel crashes it will give you much more feedback, and if it does it is likely busted ram or your motherboard...
Radiance
ROUBAL
Is your power supply unit powerful enough for this heavy config ? It looks like you need something like a 1200w monorail PSU.
davistalexander
Hey,,
I was have a problem like that with my motherboard, after adding a gtx 470
computer would freeze while rendering.
The soloution i found was to downgrade the BIOS to a previois version and i have not had any blue screen or freezes since.
The MB is an asrock x58 extreme.
Weird i know but it works ..
Davis
Win7/64 |MSI GeForce 275 Twin Frozr| Core 1720 2.4 GHz | 6GB
radiant
im turning in my computer in tomorrow. the god "kim". He is like a computer hardware expert. [like phd kind].
He was sick for like 3 months, we though he died.
He is now back and he remembers that the motherboard was bent.
Since we are still in the 1 year warrently he can replace it.
So next week it should run fine.
Return to “Off Topic Forum”
