Hey there, I'm getting a fatal render error whenever I try to render a 1920x1080 EXR sequence of 75 frames. My guess so far is that a high poly count will crash the scene, but I'm not sure.
Windows 10 Pro 64 Bit
Intel Core i7-6800K CPU @ 3.40GHz
NVIDIA GeForce GTX 980 Ti (Gigabyte)
ForceWare version: 372.54
SLI Disabled
64 GB DDR4 RAM
Octane Plugin Version 3.03-3-R1
Octane Engine Version 3.03-3
Cinema 4D R17.053
I've attatched my scene and bugreport zip. Any help is much appreciated, as I have zero clue why it is crashing and on a tight deadline.
Thank you very much!
Scene Render Crash
C. RAM Capacity (i.e. 6 GB)
- Attachments
- bugReportAndSceneFile_jamesvde_01.rar
- Bug Report Folder & Scene File called waveRoof
- (440.32 KiB) Downloaded 203 times
I'm not sure about exact reason. Maybe a bug in plugin with meshno=3 and these objects. It's a long topic.
Use layer manager to make visible all objects in object manager. then select tags and change values to 1-2.
Btw, please don't use "send all data" without any real reason. I'm gonna deprecate that soon.
A tip when crashes/errors happened: Try to delete some parts and render it until find crash reason.
True, seems a bit above what I need to know. Thank you for the tip with the layer manager.
I had to use 'send all data' as my deformer wouldn't update correctly when rendering. Unless there is another way around that.
I'll try that next time when I encounter a crash or error.
Thanks again!
Thanks again!
Ok i see. When some meshes are not updating try this option. I'm gonna check this issue after come back from a vacation.
Or this options
- fatfreemedia
- Contact:
Those softboxes are, I'm sad to say, very very bad news for Octane at the moment. I would recommend against using them if possible.
Win10 64bit | 3 * GTX970 | i7 5930k | 32GB
Win10 64bit | 2 * GTX970 | i7 4790k | 16GB
Win10 64bit | 3 * GTX980 | i7 5930k | 32GB
Win10 64bit | 3 * GTX980 | i7 5930k | 48GB
Win10 64bit | 3 * GTX1070 | i7 6850k | 64GB
