texture bake how to?
sertac.tasdemir
Hi ..
Can i use octane for texture bake inside 3dsmax?
i have 2 UV map channel. Octane supports second uvmap channel?
first channel(1) for texture tiling second channel(2) for lightmap.( unwrap flatten)
Is this possible? Need advice..
Thanks.
found this tutorial : https://www.youtube.com/watch?v=DQ0yFpMJmK8
but how to select second channel for bake?
mojave
Here you can find all documentation about texture baking:
https://docs.otoy.com/#60Texture%20Baking
To choose the UV map used to for baking you need to set the UV set baking camera attribute to the index you prefer.
sertac.tasdemir
well im not use the stand alone version.
is this possible in 3dsmax? where are the settings?
mojave
Second and third UV sets are currently not supported for baking in the 3dsMax plugin but is in our priority list and will be added soon in a new release.
Best,
