Hello to all,
There is something new about the shading artifact issue when adding normal maps or bump maps?
The workaround to increase the subdivisions operates well in small scenes (although on closeups the problem persists), but in large environments like architectural interiors with lots of fornitures, it saturated in a short time the available memory, and transfer times increase accordingly, especially in animation with large animated geometry when the scene is update frame by frame...
cheers
A.
Bump & Normal maps shading artifacts
- Liketheriver
- Contact:
- mark0spasic
Try to change Ray epsilon value.
AMD FX 6300, 24 GB RAM, Gigabyte ga-990fxa-ud5, 2x MSI GTX 780 3GB
- Liketheriver
- Contact:
It works!
thanks for the advice! that's the only parameter i had not taken into consideration
ProArt Z690 | i9 12900k | 128GB ram | RTX 3080ti | Windows11
ProArt Z890 | Ultra 9 285K | 256GB ram | RTX 5090 | Windows 11
