Hey guys,
Can anyone get this working? Doesn't matter what border mode I choose, it doesn't change for me. This is with a displacement node.
Thanks!
Mirror Border Mode - Displacement
Displacement will not pickup on the Border Mode. Pls see the link in my signature for the limitations when using Octane displacement mapping.
Gtocha. Sorry didn't see the link. I just did it in photoshop, was just trying to save some resolution.
Does this still hold true? "3) Octane assumes black pixels in the displacement map have 0 displacement. If using a displacement map where 0 is a negative displacement (for example, a map generated from ZBrush), put a "Shift" of negative half the "Amount" (ie. if the Amount is 0.01, the Shift will be -0.005)"
I remember shift being there, but now I see it says "Mid-Level"
No, you are right - this is now not valid with Octane 3.Does this still hold true? "3) Octane assumes black pixels in the displacement map have 0 displacement. If using a displacement map where 0 is a negative displacement (for example, a map generated from ZBrush), put a "Shift" of negative half the "Amount" (ie. if the Amount is 0.01, the Shift will be -0.005)"
