Export from blender to StandAlone
tamerkseniya
Hello guys,
I was searching for a way to export model textured in Blender Octane Edition into Stand Alone with all the materials. I wasnt succesfull though in finding anything usefull.. Currently I worn only on still scenes. Could you please share some info?
2 x GTX 980 Ti, 32 GB ram, i7 5820K
J.C
In render settings choose "Export scene" to ORBX. Then press Animation button.
Two important things to remember/adjust before exporting:
  • - In dimensions panel set frame range to desired range
    - In output panes set the proper file path. This is where ORBX will be exported.
System – Windows 11
kraken
....AND. IF you are having issues with the render server crashing or not starting up, the export won't work. It will just render black frames to your destination folder. So if you see those pesky files, you know somethings up with your octane server.
Win 7 64bit Ultimate SP1
Blender 2.78
4x GTX980 Ti
NVidia Driver 373.06
Octane Server 3.03.4 v.11.2
Octane SA 3.03.4
Dual Xeon E5-2686
64 GB Ram
1TB SSD
AsRock EP2C612 WS
cHirio
Hm are you sure that this works? I have never managed to import and export between blender and standalone with all materials. :roll:
mib2berlin
Hi, export work for me but you have to setup all materials for Octane.
If you have Cycles/BI material export does nothing..
Cheers, mib
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
kavorka
can you import back into Blender?
tamerkseniya
I never try importing back.. Another thing is, can we import a part of the model in to Octane scene. Lets say we adjusted scene in Octane standalone, but later a part of scene was updated. Can we somehow import only updated part or everything should be imported from zero?
Return to “Blender”
