Without artifact:
With artifact:
Here is a screenshot mid-render showing clearly how the image is being segmented in the render:
The project file is here:
https://dl.dropboxusercontent.com/u/108 ... werFog.zip
thanks wafflelad, this seems to do the trick... maybe there should be a warning in the flyout info of this setting, mentioning the possible tile problem.wafflelad wrote:Does it still happen if you turn Max Tiles down to 1? It seems to be a byproduct of how the tiling works.
