V3 Z-Depth pass not showing up in render
JonathanWinbush
I just rendered a long sequence over night and in the viewer I was able to adjust the Z-Depth pass just right so I thought it was fine but I just brought my sequence into after effects and its completely white. I set it up the same way I did in v2 but its not working now fyi.
Winbush.tv
Win10x64 / i7 SkyLake / Nvidia Titan X + 980ti / 32gigs Ram
I have explained on a few posts. it's linear by default. Means pixel values are big than 1.0 as being distance value. You can't see without saving as exr, tiff on 32/16 bit formats. Or use tonemapping on passes.
JonathanWinbush
But I did. I always render EXR 32bit and like I said it worked perfect in v2 but not in v3 unless you can see something wrong in my setup here. I had rendered this same scene in v2 a few days ago but had to make changes to the camera move so I re rendered with the same exact setting I used as when it worked.
Winbush.tv
JonathanWinbush
Ok I got it to work I changed the tonemap type from linear to Tonemapped and I getting the results I used to get.
Winbush.tv
rojharris
Phew! Thanks for that tonemapping tip. This has been driving me nuts! Its not explained well in the manual. Well spotted!
rojharris wrote:Phew! Thanks for that tonemapping tip. This has been driving me nuts! Its not explained well in the manual. Well spotted!
Do you mean this?
https://docs.otoy.com/#cinema-4d-v3-plu ... er-z-depth
KeeWe
Another solution is to change the black and white point in you compositing software.
6850k // 32 GB // 1080, 1080 Ti, 2080 Ti // Win 10 // C4D 19.068
zinogino
KeeWe wrote:Another solution is to change the black and white point in you compositing software.
Thanks for the pointer !
aggiechase37
I'm wondering if we can get a more user friendly implementation of this. Every time I go to render a z depth map, I always have to come and dig through this convoluted process, and even then I find myself troubleshooting for way longer than I'd like.
Chase
Win 10 - Intel 4770 - 2x Nvidia 1070 - 32 gigs RAM - C4D r16
http://www.luxemediaproductions.com
