ies target mode wrong results
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
boris
just played with the newest plugin version:
OctaneRender_for_3ds_Max_3.0_-_3.12
IES target mode does some strange things. sometimes it mirrors the direction in Y axes. can't really describe. see my very basic scene and play around with the target.
and very ANNOYING: the render updates only if I turn on/off the light. RELOAD BUTTON in OCTANE VIEWPORT does not update the light direction.
scene is max2015.
octane3_ies.zip
(19.65 KiB) Downloaded 159 times
P6T7 WS SuperComputer / i7 980 @ 3.33GHz / 24 GB / 1500W + 1200W PSUs / 6x GTX 680 4 GB + 1x Tesla M2070 6GB (placeholder :))
paoloverona
same problem for me, the only "trick" for make it work correctly is to set the ies light as movable proxy
intel i7 3820 3.6GHz, 16Gb 1600Hz, windows 7 professional 64bit, gtx 580 3Gb x2, Octane 3dsMax 2.58
boris
paoloverona wrote:same problem for me, the only "trick" for make it work correctly is to set the ies light as movable proxy
Oh. tnx. didn't think of that.
works like a charm now :)
boris
Yes, this is a bug in a newly made targeted IES (only in non-movable-proxy mode). Thank you for report!
Will be fixed in next version...
Return to “Bug Reports”
