Standalone 2.25 Crash
magicroma
Hi! I have a problem with Standalone version of Octane. I bought it today and i very upset... It's crush every time. I'd installed the latest CUDA Drivers and nVidia Driver. Doesn't work anyway... Please help help help...
This is log of problem:
Process: octane [764]
Path: /Applications/OctaneRender 2.25.app/Contents/MacOS/octane
Identifier: com.otoy.octanerender
Version: ???
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: octane [764]
User ID: 501
Date/Time: 2016-05-12 12:30:54.848 +0600
OS Version: Mac OS X 10.10.5 (14F27)
Report Version: 11
Anonymous UUID: 9DCCFED2-BFD6-7A4B-B029-B4959D2E12DB
Time Awake Since Boot: 2100 seconds
Crashed Thread: 0
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Library not loaded: /System/Library/Frameworks/GLUT.framework/Versions/A/GLUT
Referenced from: /Applications/OctaneRender 2.25.app/Contents/MacOS/octane
Reason: no suitable image found. Did find:
/System/Library/Frameworks/GLUT.framework/Versions/A/GLUT: open() failed with errno=93
Binary Images:
0x7fff658ca000 - 0x7fff65900887 dyld (353.2.3) <B1B370A5-479F-3533-8AD7-97B687D4F989> /usr/lib/dyld
0x7fff8b8ee000 - 0x7fff8c46fff7 com.apple.AppKit (6.9 - 1348.17) <E485D56D-3E72-34B7-99BB-BFDEE2D07BF5> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff8d392000 - 0x7fff8d655ff7 com.apple.WebKit (10600 - 10600.8.9) <8EE5A9F9-DE98-3202-92C0-23F6E6E5E274> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x7fff8f106000 - 0x7fff8f114ff7 com.apple.opengl (11.1.2 - 11.1.2) <5F355713-4637-33CD-9CBA-4B4CA43FB0FE> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff9010c000 - 0x7fff9017efff com.apple.framework.IOKit (2.0.2 - 1050.20.2) <09C0518C-90DF-3FC3-96D6-34D35F72C8EF> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff92f94000 - 0x7fff92f94fff com.apple.Carbon (154 - 157) <9BF51672-1684-3FDE-A561-FC59A2864EF8> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff95c0a000 - 0x7fff95c5bfff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <450293F7-DAE7-3DD0-8F7C-71FC2FD72627> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
Model: MacPro5,1, BootROM MP51.007F.B03, 8 processors, Quad-Core Intel Xeon, 2.4 GHz, 32 GB, SMC 1.39f11
Graphics: NVIDIA GeForce GTX 770, NVIDIA GeForce GTX 770, PCIe, 4095 MB
Memory Module: DIMM 1, 4 GB, DDR3 ECC, 1066 MHz, 0x0198, 0x393936353432362D3034372E4130304C4620
Memory Module: DIMM 2, 4 GB, DDR3 ECC, 1066 MHz, 0x0198, 0x393936353432362D3034372E4130304C4620
Memory Module: DIMM 3, 4 GB, DDR3 ECC, 1066 MHz, 0x0198, 0x393936353432362D3034372E4130304C4620
Memory Module: DIMM 4, 4 GB, DDR3 ECC, 1066 MHz, 0x0198, 0x393936353432362D3034372E4130304C4620
Memory Module: DIMM 5, 4 GB, DDR3 ECC, 1066 MHz, 0x0198, 0x393936353432362D3034372E4130304C4620
Memory Module: DIMM 6, 4 GB, DDR3 ECC, 1066 MHz, 0x0198, 0x393936353432362D3034372E4130304C4620
Memory Module: DIMM 7, 4 GB, DDR3 ECC, 1066 MHz, 0x0198, 0x393936353432362D3034372E4130304C4620
Memory Module: DIMM 8, 4 GB, DDR3 ECC, 1066 MHz, 0x0198, 0x393936353432362D3034372E4130304C4620
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8E), Broadcom BCM43xx 1.0 (5.106.98.100.24)
Bluetooth: Version 4.3.6f3 16238, 3 services, 27 devices, 1 incoming serial ports
Network Service: Ethernet 2, Ethernet, en1
Serial ATA Device: HL-DT-ST DVD-RW GH61N
Serial ATA Device: HGST HDN724030ALE640, 3 TB
Serial ATA Device: WDC WD2001FASS-00U0B0, 2 TB
Serial ATA Device: Samsung SSD 850 EVO 500GB, 500,11 GB
USB Device: Hub
USB Device: Hub
USB Device: Keyboard Hub
USB Device: Apple Keyboard
USB Device: USB Device
USB Device: Display iSight
USB Device: Display Audio
USB Device: Apple LED Cinema Display
USB Device: BRCM2046 Hub
USB Device: Bluetooth USB Host Controller
FireWire Device: built-in_hub, Up to 800 Mb/sec
Thunderbolt Bus:
MacOS 10.10.5 | Geforce GTX 770 | 2 x Quad-Core Intel Xeon | 32GB
Hi magicroma,
weird, unfortunately I don't have 10.10 on my Mac Pro anymore, but I can run Octane 2.25 on 10.9.5 and 10.11.4 with no issues :roll:
10.9.5
10.9.5
10.11.4
10.11.4
As you can see, the CUDA drivers are updated to the latest ones, while the graphic drivers come directly from Os X, no special Nvidia drivers installed on both.
Which drivers have you installed?
You can go back to the original Os X driver by installing again the 10.10.5 combo update:
https://support.apple.com/kb/DL1832?vie ... cale=en_US
magicroma
I'd installed the latest NVIDIA Web Driver: 346.02.03f01 - latest available... and CUDA driver also 7.5.26. Will 10.10.5 combo update uninstall my NVIDIA Web Driver do you think?..
Hi magicroma,
unfortunately that version is specific for 10.10.5, so I cannot install them on my system, sorry :(
My suggestion is to go back to the original osx drivers, I don't remember of other users with your specific issue :roll:
If I remember well, there should also be a specific menu or an item in the system preferences to go back to the original drivers :roll:
