Hey guys,
I've read around, tried some solutions such as updating, changing files, but so far I can't get a fix.
I load a model. I apply the TGX modifiers to it. I accidentally delete the model instead of an accessory. I hit the undo button. All textures are gone.
I have tried to save the model as a set, as a character preset, as a scene. Upon re-load, all textures are gone.
Please assist with saving textures permanently.
Using TEST latest version of Octane 3.
AD
Textures Disappearing
Moderator: BK
Tick "Load OctaneRender materials from .duf user presets" on the Preferences tab of the plugin.
If you CTRL-Z and get the deleted character back, another option to re-load the corresponding textures would be:
1.) Right-click the character in your OctaneRender materials menu (so that all material zones are highlighted)
2.) In the context-menu hover over the first option
3.) Select "Replace all active textures"
That should also do the trick.
- 3dxcentric
Paul - I did that, and it absolutely works. The trick is remembering to save the scene after you tick the checkbox
However it doesn't work for the ctrl-z undo.
Razor - Thanks for writing. I'm a fan. I do not appear to have that option.
- AD
- AD
