Textures Disappearing
Moderator: BK
3dxcentric
Hey guys,
I've read around, tried some solutions such as updating, changing files, but so far I can't get a fix.
I load a model. I apply the TGX modifiers to it. I accidentally delete the model instead of an accessory. I hit the undo button. All textures are gone.
I have tried to save the model as a set, as a character preset, as a scene. Upon re-load, all textures are gone.
Please assist with saving textures permanently.
Using TEST latest version of Octane 3.
AD
Tick "Load OctaneRender materials from .duf user presets" on the Preferences tab of the plugin.
TRRazor
If you CTRL-Z and get the deleted character back, another option to re-load the corresponding textures would be:
1.) Right-click the character in your OctaneRender materials menu (so that all material zones are highlighted)
2.) In the context-menu hover over the first option
3.) Select "Replace all active textures"
That should also do the trick.
W10 64 bit | i7 3770K | MSI Geforce RTX 2080 (8GB) + GTX Titan Black (6GB) | 32 GB DDR3 RAM
3dxcentric
Paul - I did that, and it absolutely works. The trick is remembering to save the scene after you tick the checkbox :) However it doesn't work for the ctrl-z undo.
Razor - Thanks for writing. I'm a fan. I do not appear to have that option.
- AD
Return to “DAZ Studio”
