standard blend node conversion
HHbomb
Hi, could it be possible to have the standard blend node to be converted to mixed material and mixed texture, as it is a very used node, and all following nodes are not converted, it is a pain... (don't seems to be so hard ?) Thanks
azen
The complexity of material conversions can vary wildly based on a myriad of factors. This would need to be tested out before I can make a solid confirmation of feasibility. I'm optimistic that it will be possible to add this to the converter. This will likely appear in the early 3.x releases of the plugin, before making it's way to the 2.x branch.
HHbomb
thanks Azen, Jim just done it :-)
azen
Last thing I wanted to do was get your hopes up, considering the current workload on developers right now. Really happy to find that this was one of the simpler requests though.
Hope this improves your workflow going forward!
Return to “Autodesk 3Ds Max”
