Hello,
I have recently obtained Octane for blender. My Blender Octane Edition file crashes instantly after I load my file. I can not edit geometry or materials, sometimes it even crashes while loading the scene. I tried it on several different scene with similar amount of faces, around 200-300 k, not that heavy, it failed in al scenes.
After several trials Octane Server failed and I had to reactivate the license inside of blender. After I enter my stand alone and plugin usernames and passwords, Microsoft give warning that Octane has stopped working. Now I can not active it inside blender at all.
Only stand alone version seems to work fine, but I didnt test it on my project scenes yet and I need it to work inside blender. I upgraded my Nvidia drivers to latest version and also Visual C++ Redistributable Packages, Is there anything I miss?
Please help me, I really want to believe I didnt spend my resources in the air on the failing program.
My system is;
Windows 7
i7 5820K
dual GTX 980 ti SLI
32 gb Ram
Blender v 2.75
Octane Server and Blender version fails
- mib2berlin
Hi, they are may some bugs still but have no problems with crash on server for a long time.
Make sure you have the latest version, we are on Blender 2.76, Server 9.11.
Disable SLI on your cards, this makes problems something or at least slowdown render on Octane.
If possible upload .blend that crash for you.
Cheers, mib
Cheers, mib
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
- tamerkseniya
This is the version I see the latest in the list of Downloads. But it is blender 2.75 not 2.76. How can I upgrade to 2.76?
Windows 2.23.2 - 9.3 Octane Server stable
You can download my scene form here
https://www.dropbox.com/s/9fhrpeaji4fij ... 6.rar?dl=0
Thank you for help
Thank you for help
- mib2berlin
Hi, check here: viewforum.php?f=113
Testing now, mib
OK, all textures/materials are Cycles materials, Octane cant use them.
It seams you have linked objects in this .blend, therefor I cant render the file correctly.
Render is working but only with blank materials.
Cheers, mib
Testing now, mib
Cheers, mib
- tamerkseniya
Yeah I did some work in cycles before getting Octane. I will adopt all materials to octane once I get it to work without crashing.
I will try tomorrow 2.76 or higher to see if the problem with server is solved and post the result,
Thanks a lot for your help!!
2 x GTX 980 Ti, 32 GB ram, i7 5820K
- tamerkseniya
Unfortunately version 2.76 caused same error. I tried activating license in the clean new scene of blender.
http://prntscr.com/auwzwc
(this is the error, in Turkish. Just standard OctaneServer.exe stopped working mesage.)
Any other ideas, maybe something about system, or drivers?
- tamerkseniya
I tested it on another two computer and it works there. So this is related particularly to my PC.
I tested versions 2.76, 2.75 and 2.70 on my PC with disabled firewall and anti virus. No success, server fails.
Any other ideas what can cause Server to fail?
- mib2berlin
Hi, I would post to support, they can check your logins.
https://home.otoy.com/get-support/
Cheers, mib
Cheers, mib
- tamerkseniya
Hello again,
After trying numerously reinstalling latest Nvidia drivers, different plugin buildings for blender we still have no solution for this particular computer.
Support suggested installing latest Nvidia drivers which we already did and no other help recieved
It is really frustrating... Is there a way to get report of the error? Maybe it is a bug caused by system settings etc...
