Hi everybody
Would you have any idea how to set the rendering (or anything else) up to remove the trembling on reflective background? I've met such problem even with DOF.
Dan
Trembling background
- Attachments
- vibrating bgr.mp4
- Trembine bgr
- (3.7 MiB) Downloaded 2108 times
What's coherent ratio?
Hi Aoktar
Thank's a lot for your quick reply. True, I've got used the coherent ratio (0,4). I just rendered a new sequnce and now, with no CR seems to be good.
Does it means that the CR cannot be used for animations at all?
Dan
Dan
- Attachments
- NO COHERENT.mp4
- (993.79 KiB) Downloaded 2085 times
Not exactly. Try with "static noise" enabled. It should be much better.
Please make some tests.Nutrend wrote:With the same level of CR or lower?
Thanks! I don't have time for everythings. Also testing it yourself best way as my opinion and help to understand more.Nutrend wrote:I'm doing it just now. Anyway you've got my great thanks.
Regards
D
Hi Nutrend,
off course you can use CR with moving frame, but its better to have static noise ON and set a minimum Samples (ex: 748spp) to let time to Octane to investigate what'is the "coherent ratio".
I can't technically explain better , but tha's sure it is a real time saver when it's correctly set.
pxlntwrk.net
pxlntwrk.net
