Trembling background
Nutrend
Hi everybody
Would you have any idea how to set the rendering (or anything else) up to remove the trembling on reflective background? I've met such problem even with DOF.
Dan
vibrating bgr.mp4
Trembine bgr
(3.7 MiB) Downloaded 2104 times
What's coherent ratio?
Nutrend
Hi Aoktar
Thank's a lot for your quick reply. True, I've got used the coherent ratio (0,4). I just rendered a new sequnce and now, with no CR seems to be good.
Does it means that the CR cannot be used for animations at all?
Dan
NO COHERENT.mp4
(993.79 KiB) Downloaded 2080 times
Not exactly. Try with "static noise" enabled. It should be much better.
Nutrend
With the same level of CR or lower?
Nutrend wrote:With the same level of CR or lower?
Please make some tests.
Nutrend
I'm doing it just now. Anyway you've got my great thanks.
D
Nutrend wrote:I'm doing it just now. Anyway you've got my great thanks.
D
Thanks! I don't have time for everythings. Also testing it yourself best way as my opinion and help to understand more.
pxlntwrk
Hi Nutrend,
off course you can use CR with moving frame, but its better to have static noise ON and set a minimum Samples (ex: 748spp) to let time to Octane to investigate what'is the "coherent ratio".
I can't technically explain better , but tha's sure it is a real time saver when it's correctly set.
pxlntwrk.net
