Transparent mesh when mesh not closed
cristiangiro
Hello
i'm having this problem
whenever i have an open mesh, for instance when i keep the invisible part with no polys; i see through it, like it was a bit transparent
i can see the background or the lights through it
any solution for this? i searched the forum but no luck
thanks in advance!
Can you post some screenshots showing the problem pls?
cristiangiro
hi,
as you can see i can see the hole through the mesh even if the material is not transparent
any suggestion? i'm sure is some dumb mistake I've made
thanks!
Can you send me the .lxo pls?
cristiangiro
done!
Thanks for sending through the file. The Opacity of the First Material in the Material Mix is 0.968, so it is very slightly transparent. Set the Opacity to 1 and the mesh is no longer partially transparent.
cristiangiro
sorry, that was awkward, but in my defense i was sure it was my fault :))))
thanks!
Return to “Foundry Modo”
