Workflow to create high resolution texture fabrics.
Syd_86
Hello everyone!
I need to create many fabric materials in high resolution.
So, I have to create different textures normalmap, bump map or height map. In other cases I need to highlight details such as cloth, eg agnellato plaid.
Starting with a high-res image, how do I proceed?...(Obviously not these)
Image Image
THANKS ALL!
Hi Syd_86,
if you could be more specific about your workflow...
Do you already have the textures or you have to produce them with Octane?
What is the octane version used?
For example, if you work in Standalone and you alteady have the textures, you can have a Lua script that automate the material creation based on the texture name :roll:
Syd_86
Hello Beppe, :)
I have, OR 2, OR 3 alpha (Standalone)
I will photograph the cloth, then I place the image on photoshop and create the seams...then, i have the image of the color (diffuse).
I need to create bump maps, displacement map for High Definition.
How can I add details, like threads of a fabric? (Image 2) ... octane can not import. Or am I wrong?
How to proceed tips? to create all the textures? .. and for details visible on the second picture? How do I create them?
How to isolate weaving of the texture? to use it in normal maps, displacement map.
What can I do with Lua script? I don' t know.
Thanks! ;)
Yambo
This is very interesting topic. I tried before to get very high quality photo-real fabrics, and didn't get 100% satisfying results.
I guess you should start experiment with textures, combine all the maps and see how it goes.
Post your progress here and i will be happy to assist you on my free time.
4x 980ti EVGA | 5930k | Asus X99 E WS 3.1 | corsair 64GB RAM |SSD 500GB system + SSD 2TB working files + 6TB HDD storage WD |
Phanteks Enthoo Primo | 1600W EVGA T2 BLACK | It's the fastest 4x980ti build: http://goo.gl/hYp8e0 :)
https://yambo.me
Syd_86
Ok Yambo!
Thanks!
Hi Syd_86,
there are a lot of software that are designed to extract maps from a given image, here is the first one that comes to my mind:
http://www.crazybump.com
Some time ago, an user has posted a free GPU version but it seems that I cannot find the link, sorry.
Probably, there should be already scanned materials out there, I guess, maybe some other users can share some links :roll:
The detail of the wool could be done with a conjunction of displacement and hairs, I guess :roll:
Lua script could be useful only in a second time to automate the material creation, but the big work is on the texture side.
smicha
Yambo
smicha wrote:My favorite one
https://www.pixplant.com/
I didn't knew this one! looks promising, i will try it definitely.
Thanks.
https://yambo.me
Syd_86
Yes! I know crazybump, ... no PixPlant
I also know KNALD, Shadermap ...
In this way I have to go to attempts. Maybe I need to get a better picture ...
It is simpler a 3D scan of each fabric and make a normal map / heightmap., and some tweaking of phosohop
... Too bad I have not a 3D scanner ... Diffuse map would not fit with the normalmap. Unless the scan can capture all of this information.
smicha
Use a DSLR camera at low ISO. Shoot the material (on a tripod) from different angels and reconstruct the texture in 3D Agisoft Photoscan. Export the obj to zbrush for further works.
