Bump value behaviour
TheImageFaculty
Just wanted to check if this is the expected behaviour as it has caught me out a couple of times.
I was trying to plug an image into the bump value of an octane override and wasn't seeing anything happen in the OctaneRender Viewport.
Bump value in schematic has to have a value added before a map is piped in otherwise it does not pick up map as driver of the bump. Strange behaviour as I would expect the map to directly pump it's own values into the bump attribute. Is this correct/expected behaviour?
The Image Faculty ApS
https://theimagefaculty.com
This doesn't sound right - are you able to post a screenshot of the Schematic pls? If you add a Bump map Effect to the Shader Tree prior to adding the Octane Override, you can see from the generated Octane Override the correct connections for the bump map.
TheImageFaculty
Hi Paul,
I am not seeing this behaviour at the moment, it may have been an error on my part. If I come across it again I'll let you know. It was happening when I added the image via the schematic, not via the shader tree.
Return to “Foundry Modo”
