I've using 2.16 version for several weeks and I noticed that many elements are not working well.
If you want to get, Zdepth or shadows for example, they don't work at all. Whatever you do, either setting the right zdepth value in the elements window or using info channels with the right settings, nothing seems to give you a right output.
Can I get some help from the otoy team? I started another topic about this with a previous version and things worked out well, but with the 2.16 it's impossible.
Anyone with the same problem?
thank you
3dsmax version 2.16 elements not working properly
