3dsmax version 2.16 elements not working properly
maxpardo
I've using 2.16 version for several weeks and I noticed that many elements are not working well.
If you want to get, Zdepth or shadows for example, they don't work at all. Whatever you do, either setting the right zdepth value in the elements window or using info channels with the right settings, nothing seems to give you a right output.
Can I get some help from the otoy team? I started another topic about this with a previous version and things worked out well, but with the 2.16 it's impossible.
Anyone with the same problem?
thank you
Goldisart
I dropped 15 version
JimStar
maxpardo
It's not clear from your post what exactly is wrong... If you think it may be a bug - you need to give a detailed description of what's wrong and how to reproduce.
maxpardo
I will post some screenshots jimstar. Basically zdepth is not working. It's pure black and white, no depth. No matter what settings you use.
Once I get to my computer I will post some examples
Best regards
Return to “Autodesk 3Ds Max”
