Hi folks,
I'm having an issue where my geometry (flat, non-trangulated) is rendering fine in live viewer but then totally messed up in final render. The final render looks like its ignoring the phong tag, but only on some surfaces?
There is a phong tag on the object and its set to 40 degrees. See attached. Version 2.24.2 Cinema R17
Any ideas?
Roger
Phong problems in render not in live-view
Is it octane output? If so scene please.
Just send this object with current setup. You can use message system of forum on top.
It seems related with "rounded edges" parameter. But i'm not sure why behaves different on final output. I'll take a look to understand.
Hi Ahmet,
I've rendered a few frames and discovered that rounding is causing errors on other surfaces/objects when rendered in picture viewer, even though they look fine in the live view window.
I'm turning it off on everything for now just to be safe.
R
R
Only potential issue in plugin is wrong unit calculation for final output. Rest of problem is about renderer. I suppose that guys will say don't use it on problematic meshes.
