Octane 3.00 alpha4 Import 39.9 M Tri Polygons
Render Failed 5824.7MB/12022MB/12288MB
The screen shot was from the Standalone. There you can find the log under Help -> Open log....jang2235 wrote:Octane Log File....
Where is the log file?
Once again the problem of creating a situation I will send a log file.
I did not do something special.
But only it brought in 39.9 million polygons.
And just press the render button.
I wonder if it is my problem or a problem with another person.
It will ever shown symptoms to test the Export Orbx only in Lightwave.
It doesn't seem to be a resource issue. Could you please send us the scene so we can investigate? Thank you.jang2235 wrote:Started logging on 14.02.16 20:04:32
OctaneRender 3.00 alpha 4 (3000004)
CUDA error 719 on device 2: An exception occurred on the device while executing a kernel. The context cannot be used anymore and must be destroyed. All existing device memory allocations from this context are invalid and must be reconstructed.
-> failed to launch kernel (ptBrdf1)
device 2: direct light kernel failed
CUDA error 719 on device 1: An exception occurred on the device while executing a kernel. The context cannot be used anymore and must be destroyed. All existing device memory allocations from this context are invalid and must be reconstructed.
device 1: direct light kernel failed
CUDA error 719 on device 0: An exception occurred on the device while executing a kernel. The context cannot be used anymore and must be destroyed. All existing device memory allocations from this context are invalid and must be reconstructed.
device 0: direct light kernel failed
