Convert Octane Scatter objects to C4D instances?
martincarlson
Is this possible? Say Octane scatter has generated 100 trees for me. I like the postition of all hundred trees except in one place where I want to remove 10 trees.
Martin Carlson, Visual and Audial Designer at Katzenwaffe Creative Studio | www.katzenwaffe.se | Soundcloud | Twitter
Intel Core i7-5930K / ASUS X99-E WS / 2 x EVGA GeForce GTX TITAN X 12GB / 32 GB RAM / Windows 10 / C4D R16 / Octane Standalone 3.03.3 / OctaneC4D 3.03.3-R1
Hi Martin,
probably I have not understood the question, but can't you use a vertex map to remove the 10 trees?
martincarlson
bepeg4d wrote:Hi Martin,
Ah. Yes. That might work. Thanks!
VVG
Convert Octane Scatter to object (curent state to Object)
how?
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
milanm
VVG wrote:Convert Octane Scatter to object (curent state to Object)
how?
1. Set Maximum Time to 1 in Project Settings if you don't want any animation.
2. Delete everything except the Scatter object and all geometry that you want to convert.
3. Start LiveViewer -> Export To ... -> Animated Package (orbx)
4. Open the exported orbx in Standalone and use File -> Unpack package...
5. Import geometry.abc from assets folder in C4D with Scale option set to Meters.
6. Use the free Instance Vault plugin and Search option in Object Browser to convert objects to instances.
Regards
Milan
Colorist / VFX artist / Motion Designer
macOS - Windows 7 - Cinema 4D R19.068 - GTX1070TI - GTX780
VVG
how?
Regards
Milan
thanks, I will try this method.
Try to switch to "Display Type=Object" and press 'C' while clones are visible.
VVG
aoktar wrote:Try to switch to "Display Type=Object" and press 'C' while clones are visible.
cool. Thanks!
milanm
Hahaha. You killed me. Nice. Thank you. I didn't even try that... (shaking my head)
Ahmet. Please, if you have any more tricks like that, that maybe only you know about, because, well, you made the plugin, it would be really nice if you shared them with us on the forum occasionally. Maybe in a sticky topic. No video, just short text posts just like your tip above. Only plugin specific stuff, about scatter, node editor, material stacking etc. Short and quick.
I see some tips like that in the release threads, but they get lost after a new version comes out. It's hard to keep track.
Regards
Milan
Regards
Milan
;) surely happy to help and I'll add this and more to end of manual, thanks!
