displacement causes polygons to disappear
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
WhyGee
I've noticed that when there is displacement on an object that has polygons with zero surface area in their uvs, those polygons disappear in the render. I would expect the texture to simple smear over these polygons. I've attached a simple scene demonstrating this with a switch node that nudges the uvs just slightly to "fix" the behavior. This is not an ideal workaround though.
Could be a standalone issue but I don't think I can isolate this without someone testing this on another package.
Thanks alot.
Yaniv
Plugin 3.00.4.0
Standalone 3.00 alpha 4
displacement_uvs.rar
(1.63 MiB) Downloaded 313 times
juanjgon
Yes, this is an Octane limitation. I have the same behavior in the Standalone. I will report the issue to the Octane team.
WhyGee
Thanks alot!
Return to “Bug Reports”
