Multilayer file EXR
JavierVerdugo
Hello,
i renderer a project with multilayer file with diffuse, reflection, and ID (1,2 y 3) for alphas.
When I export my EXR sequence into After effects and I apply EXtractoR plugin I only get the diffuse and Reflection, but IDS don't appear.
Do you know what I'm doing wrong?
TheOracle
Are you sure you used an object tag with the correct ID number set to the objects?
Win 10 64 bit + Linux Ubuntu | Nvidia RTX 2080TI | AMD Ryzen Thredripper CPU 2970WX 24-Cores/48-Threads | Houdini - Cinema 4D - Maya - 3Dsmax
JavierVerdugo
Very sure,
In the picture viewer I saw the Object layers mates channels.
But when I exported to after effects as multi file only could export beauty channels.
I have to say I was using octane 3 alpha.
My question is, can you do this process with octane 2? (Multilayer EXR file and exporting with EXtractoR every channel including mate channels) Maybe is just a problem with alpha.
Cheers
Can you see correctly rendered maskIDs in picture viewer before saving? Are you using Octane render passes section to save exr file?
JavierVerdugo
Yes,
I saw mask Ids in picture viewer and saving a multilayer EXR in octane render passes.
As I said, when I exported the Exr with EXtractoR, I could export diffuse and reflection from the multilayer but the Mask IDS were missing. However in the picture viewer I could see Diffuse, reflection, mask ID 1, mask ID 2, mask ID 3.
Used octane 3 alpha for this render.
