Odd Eye issue
Moderator: BK
bpzen
anyone know why this is happening, there is no displacement on the eyes, face etc... i tried turning opacity to 0 for all the eye parts but still happening.
https://www.dropbox.com/s/8ybezrs66c1ui ... e.png?dl=0
Octane 3.0 latest plugin, not happening on other models in same scene, tried diff eye texture......... same result.
Model is
http://www.daz3d.com/jenara-for-genesis-3-female
Win 7 64bit, Titan 6 Gig and GTX770 4Gig, Intel 3.75GHZ, 24Gig RAM, Poser 2014 patched
Looks like the tear geometry is sharing the same vertex coords as the eyeball. Turn auto-ray epsilon OFF, and manually set it to something like 0.00001, or pull the vertices away from each other.
TRRazor
Yup, as Paul said, the tear material is intersecting either with the Eye Moisture, Cornea and/or Sclera geometry.
Moving these further apart can help, but in this case this might be a harder task to do, since you can't manually move the individual eye geometry parts.
Try the rayepsilon trick as Paul suggesteed, that should help fine for this small geometry tear.
cyprine
TRRazor wrote:since you can't manually move the individual eye geometry parts
its a pain in the butt: in zbrush , move topologicaly tool (brush ?) does the trick - use polypaint (uv map) so its a lil clearer, this area is kind of crowded.
Return to “DAZ Studio”
