Cant get high resolution details to render in 902
NeoCortex
I cant seem to get Octane render for Modo to render high resolution details on any of my models with subdivisions I am using Modo 902 and the latest version of the plugin for Modo but all my meshes look low resolution when I try to render them in Octane. Is there any way to fix this can some please help? Thanks in advance
Hi
Which actual version of the plugin are you using pls?
Can you post a sample scene and screenshot demonstrating the issue.
Was rendering working correctly on Modo901?
Have you checked that you don't have Load Cage ticked in the Mesh settings?
NeoCortex
Hi I am using the latest Octane Modo plugin 2_24_2_89 64bit I have this problem with all of my meshes using multiresolution sculpting and sculpt layers I have also had this problem with 901 also I have load cage ticked already but it dosent fix this sorry. Here are two screenshots of a basic sphere with some quick sculpt details it looks fine in the Modo viewport but the polygons look faceted in Octane when I try to render it which is strange
NeoCortex
Hi Thanks I got it working now I reopened the file and unchecked load cage then opened it in octane and its working now Thanks again :)
Return to “Foundry Modo”
