Render to mplay problem
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Stassius
Windows 7, Houdini 15.0.313, Octane Plugin v2.24.2
Video - GTX770 4Gb
Every time i try to render animation to mplay window, Octane and Houdini freeze on frame number 12. It just stop doing anything with progress-bar and when i press "Interrupt" Houdini crashes.
I tried different scenes with different amount of geometry - it's always frame 12.
juanjgon
I have fixed this problem for the Octane 3 plugin few days ago. I was thinking that the last Octane 2.2 plugin builds also had this problem fixed, but from your post it is clear that the problem is still there.
Can you please try this new build of the Windows Octane 2.2 for H15.0.313 plugin too see if it works fine in your computer?
https://render.otoy.com/plugindownloads ... _Win64.zip
Stassius
Yes, it works now, thanks.
Another bug - when i close IPR window with "Pause" pressed, next time i open IPR it just won't render anything. You have to unpress Pause (nothing happens), close window and open IPR again (it begins to render).
juanjgon
I will fix the pause problem for the next build. Thanks for reporting!
Stassius
And another one. "Save parameter as permanent defaults" is not working. Say in render target node or in Octane rop node. And when i try to save preset, it shows visualisation menu. Is it even possible to use presets? It would be handy.
juanjgon
I am not sure how this feature works in the HDK, anyway I will try to support it in the future.
Stassius
When you render to mplay with camera resolution overriden to 1/3 (From 1280x720) picture distorts in funny way (after render). If you need, i can make a screenshot.
Is there any chance to update 2.24 version with this bugs fixed, or version 3 now is the first priority?
juanjgon
This problem with the MPlay is fixed in the current Octane 3 plugin build.
The 3.0 plugin is my priority now, but I could try to fix some of the critical bugs in the 2.2 code branch later if needed.
Are you working only with the 2.2 plugin version?
Stassius
Another bug - now on 3.0.4
Transform nodes in shader context work fine but every time Scale parameter accidently hit zero (say i trying to catch number with ladder), Houdini instantly crashes.
juanjgon
Can you send to me a sample scene with this problem? I am not able to reproduce it here.
Return to “Bug Reports”
