Windows 7, Houdini 15.0.313, Octane Plugin v2.24.2
Video - GTX770 4Gb
Every time i try to render animation to mplay window, Octane and Houdini freeze on frame number 12. It just stop doing anything with progress-bar and when i press "Interrupt" Houdini crashes.
I tried different scenes with different amount of geometry - it's always frame 12.
Render to mplay problem
C. RAM Capacity (i.e. 6 GB)
I have fixed this problem for the Octane 3 plugin few days ago. I was thinking that the last Octane 2.2 plugin builds also had this problem fixed, but from your post it is clear that the problem is still there.
Can you please try this new build of the Windows Octane 2.2 for H15.0.313 plugin too see if it works fine in your computer?
https://render.otoy.com/plugindownloads ... _Win64.zip
When you render to mplay with camera resolution overriden to 1/3 (From 1280x720) picture distorts in funny way (after render). If you need, i can make a screenshot.
Is there any chance to update 2.24 version with this bugs fixed, or version 3 now is the first priority?
This problem with the MPlay is fixed in the current Octane 3 plugin build.
The 3.0 plugin is my priority now, but I could try to fix some of the critical bugs in the 2.2 code branch later if needed.
Are you working only with the 2.2 plugin version?
