Account Activation 2.24.1R3 - R16.05 OSX 10.9.5
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
yafet
Hi guys, I'm having an activation problem recently and I believe it may be a bug because no matter what I do (how many times I deactive and re-setup) I can't seem to fix it.
Even if the plugin is activated without errors and with a clean setup, it searches for connection everytime I restart C4D. If the computer is connected it starts just fine but if not; I get the error 'Unable to connect' and Octane is not working after that. I tried to deactivate from the site and remove the plugin,re-setup and activate on normal order a couple of times but I get the same error everytime when I'm not connected.
I'm not sure if this may be the issue but Octane remembers my ID and pass(and later standalone's data) everytime when I remove the plug-in and it tries to connect&activate automatically even with a fresh setup.Is there a way to remove all the data by Octane in C4D, so I may enter it manually for the both plugin and standalone? Maybe that way it will activate once and for all like the old times :)
Obviously you don't need to install/reinstall plugin, etc.. This will not help to anything i suppose. There is nothing which is related with plugin. Just check that something is changing on your hardware like network interface, etc....
abstrax
Could you please try it with a 2.24.2 build?
abstrax
We had a look and it is an issue on our side.
yafet
Thank for the feedback (I've tried it with 2.24.2 too still the same problem btw)
I switched back to 2.23.2 and its working fine now.
yafet
now 2.23.2 doing the same problem! it was working fine since i last posted, but out of nowhere it started to happen again.i can't solve it and don't know what is wrong.
i'm not changing any setting or connection parameter also it was already activated and working fine without connection.
Return to “Bug Reports”
