Hi Guys,
has anyone been able to batch render an ncloth simulation in Maya using Octane? do please share your workflow.
Batch Rendering a Scene with Ncloth Simulation
Solomon W. Jagwe
did you use the Cache first or did you render straight out?prodviz wrote:I rendered a job recently using ncloth. All rendered ok.
If you are having issues, you could bake the sim or output as alembic and re-import.
Solomon W. Jagwe
I figured it out. It's now working.solomon wrote:did you use the Cache first or did you render straight out?prodviz wrote:I rendered a job recently using ncloth. All rendered ok.
Solomon W. Jagwe
I had to change from Realtime to Frame by Frame playback of the Simulation.prodviz wrote:The job was a while back, but I'm pretty sure I baked the sim.
Out of interest, what was your solution?
Solomon W. Jagwe
