displacement repeat
jagger
Hi, trying to learn to use disp in modo I cant fix this, the disp is repeated around the mesh but the "repeat" atribute is in "reset" mode, but octane is ignorint it..
how to fix this? (its a simple cube mesh with the default uv map)
thanks
intel i7 3770k // 2 x Evga Titan Superclocked 6gb Vram // 16gb RAM
http://www.octavioalonso.com
As per the Displacement notes in my forum signature, the Border Mode is ignored for Octane Displacements, so the textures will always repeat. I'm not sure if the demo version supports this or not, but if you are running Modo SP3, you can turn on the Render Cache (Preferences->Octane), and the micro-displacement polygons will be used by Octane as geometry. This can be slow, but gets around the Octane displacement limitation.
smuseus
Could you please provide a link to those notes...?
and any idea when you will fix your displacement system (tearing my hair off in frustration).
smuseus
And why can't you explicitly note these limitations in your documentation?
https://docs.otoy.com/StandaloneH_STA/S ... cement.htm
Would save wasted hours for those of us hacking out the reason for why the settings just doesn't work..
Displacement mapping limitations have changed recently. I suggest looking at the Octane 3.07 and 3.08 (TEST) release notes, in particular the Texture Baking node.
Return to “Foundry Modo”
