Exporting animated ORBX and only getting 10 frames
longshoes
Would love to get some help on this - maybe I am missing a setting somewhere.
I have been trying to export an animated camera + animated character with the animated ORBX export. However, on export it stops after 10 frames of animation. Am I missing a setting?
I can export more frames when I do a regular alembic (not octane alembic) export. When I do an octane alembic export I get the same 10 frames issue.
Help would be highly appreciated.
More info is needed to understand what the problem is... Would be helpful to have your scene whith this issue...
longshoes
Thanks for the reply - I have the scene at work and probably can't share due to client data.
I will try to explain better until I can get you a file.
  • - I have an animated camera and animated character in a Maya scene with 120 frames of animation.
    - I used the "animated ORBX" export to create an orbx file.
    - During export the file stops after 10 frames of animation instead of scrubbing through all 120 frames.
    - When I open the orbx in Octane standalone I only have 10 frames of animation as well.
    Exporting the file with regular alembic I can get all 120 frames by setting the export to the time slider - but I prefer an ORBX file than the regular alembic
Does this help JimStar? If not I can provide a file on Monday. Is there any added documentation or a manual that I can use to troubleshoot?
Enable please the verbose mode in Octane settings and share the Maya render-log file...
longshoes
Ok will do so when I return to work. Thanks for the help.
longshoes
Hi JimStar,
I am attaching the Maya 2015 test scene with 120 frames of animation. I am attaching it as a txt file since the board doesn't allow .ma extensions.
I enabled verbose mode for the Octane settings but I was unable to find a Maya render-log file. mayaRenderLog doesn't exist on my computer either. I don't think there is one being generated since I am not rendering; only exporting an orbx. (I can send you the generated orbx as well.)
Here is the script editor output:
file -force -options "" -type "OctaneRender animated scene" -pr -ea "D:/00_WORK/12_DSIII/test/sphere_orbx_test.orbx";
// Octane: starting animation of frame 1... //
// ****************************** THIN LENS CAMERA ********************************* //
// Name: perspShape //
// Orthographic: 0 //
// Film width: 35.999928, Focal length: 35, calculated FOV: 54.432129 //
// Aperture: 1 //
// Aperture edge: 1 //
// Distortion: 0 //
// Auto-focus: 1 //
// Focal depth: 100 //
// Persp. correction: 0 //
// Stereo mode: 1 //
// Stereo output: 0 //
// Stereo distance: 0.02 //
// Near clip depth: 0.01 //
// Pixel aspect ratio: 1 //
// Aperture aspect ratio: 1 //
// Camera: X: 16.832283, Y: 12.624212, Z: 16.832283 //
// Target: X: 0, Y: 0, Z: 0 //
// Up: X: -0.331295, Y: 0.883452, Z: -0.331295 //
//     IMAGER: //
// Exposure: 1 //
// Highlight compression: 0 //
// Gamma: 1 //
// Response: 105 //
// Vignetting: 0.3 //
// Saturation: 1 //
// Hot pixel removal: 1 //
// Premultiplied alpha: 0 //
// Min display samples: 1 //
// Dithering: 0 //
// White saturation: 0 //
//     POSTPROCESSOR: //
// Enabled: 0 //
// Bloom power: 1 //
// Glare power: 0.1 //
// Glare ray count: 3 //
// Glare angle: 15 //
// Glare blur: 0 //
// Spectral intensity: 0 //
// Spectral shift: 2 //
// 0:00 Octane kernel set: Direct Lighting //
// Octane: Scene scale factor: 1 //
// 0:00 Device "1:  GeForce GTX 980 (compute model 5.2)" is DISABLED //
// 0:00 Device "2:  GeForce GTX 980 (compute model 5.2)" is DISABLED //
// 0:00 Device "3:  GeForce GTX 980 (compute model 5.2)" is DISABLED //
// 0:00 Device "4:  GeForce GTX 980 (compute model 5.2)" is DISABLED //
// Warning: Octane: No CUDA devices choosen to render on. Rendering on the second one: GeForce GTX 980 (compute model 5.2) //
// Network rendering is DISABLED //
// 0:00 Octane engine: creating meshes... //
// 0:00 Gathering Mesh objects data... //
// 0:00 Setting Mesh data of mesh: pSphereShape1 //
// ****************************** MESH DATA ****************************** //
// Number of vertices: 1562 //
// Number of normals: 1562 //
// Number of UVs: 1677 //
// Number of polygons: 1560 //
// Number of vertex indices: 6240 //
// Number of normal indices: 6240 //
// Number of UV indices: 6240 //
// Number of material indices: 1560 //
// 0:00 ...done setting Mesh data in 0:00 //
// 0:00 Voxelizing... //
// Warning: Octane: Material "lambert1" is not Octane material, changing to "Gray"... //
// 0:00 ...done,  //
// 0:00 Gathering Subdiv objects data... //
// 0:00 ...done,  //
// 0:00 Gathering Octane Light objects data... //
// 0:00 ...done,  //
// 0:00 Gathering Instancer objects data... //
// 0:00 ...done,  //
// 0:00 Gathering Hair objects data... //
// 0:00 ...done,  //
// Octane: no mesh data for general mesh //
// 0:00 ...done creating meshes //
// 0:00 Octane mesh data is set to render engine. //
// Octane: starting animation of frame 2... //
// Aperture: 1 //
// Distortion: 0 //
// Auto-focus: 1 //
//     IMAGER: //
// Exposure: 1 //
// Gamma: 1 //
// Response: 105 //
// Saturation: 1 //
// Dithering: 0 //
// Enabled: 0 //
// Glare blur: 0 //
// Octane: starting animation of frame 3... //
// Aperture: 1 //
// Distortion: 0 //
// Auto-focus: 1 //
//     IMAGER: //
// Exposure: 1 //
// Gamma: 1 //
// Response: 105 //
// Saturation: 1 //
// Dithering: 0 //
// Enabled: 0 //
// Glare blur: 0 //
// Octane: starting animation of frame 4... //
// Aperture: 1 //
// Distortion: 0 //
// Auto-focus: 1 //
//     IMAGER: //
// Exposure: 1 //
// Gamma: 1 //
// Response: 105 //
// Saturation: 1 //
// Dithering: 0 //
// Enabled: 0 //
// Glare blur: 0 //
// Octane: starting animation of frame 5... //
// Aperture: 1 //
// Distortion: 0 //
// Auto-focus: 1 //
//     IMAGER: //
// Exposure: 1 //
// Gamma: 1 //
// Response: 105 //
// Saturation: 1 //
// Dithering: 0 //
// Enabled: 0 //
// Glare blur: 0 //
// Octane: starting animation of frame 6... //
// Aperture: 1 //
// Distortion: 0 //
// Auto-focus: 1 //
//     IMAGER: //
// Exposure: 1 //
// Gamma: 1 //
// Response: 105 //
// Saturation: 1 //
// Dithering: 0 //
// Enabled: 0 //
// Glare blur: 0 //
// Octane: starting animation of frame 7... //
// Aperture: 1 //
// Distortion: 0 //
// Auto-focus: 1 //
//     IMAGER: //
// Exposure: 1 //
// Gamma: 1 //
// Response: 105 //
// Saturation: 1 //
// Dithering: 0 //
// Enabled: 0 //
// Glare blur: 0 //
// Octane: starting animation of frame 8... //
// Aperture: 1 //
// Distortion: 0 //
// Auto-focus: 1 //
//     IMAGER: //
// Exposure: 1 //
// Gamma: 1 //
// Response: 105 //
// Saturation: 1 //
// Dithering: 0 //
// Enabled: 0 //
// Glare blur: 0 //
// Octane: starting animation of frame 9... //
// Aperture: 1 //
// Distortion: 0 //
// Auto-focus: 1 //
//     IMAGER: //
// Exposure: 1 //
// Gamma: 1 //
// Response: 105 //
// Saturation: 1 //
// Dithering: 0 //
// Enabled: 0 //
// Glare blur: 0 //
// 0:01 Setting Mesh data of mesh: pSphereShape1 //
// 0:01 ...done setting Mesh data in 0:00 //
// 0:01 Voxelizing... //
// Octane: starting animation of frame 10... //
// Aperture: 1 //
// Distortion: 0 //
// Auto-focus: 1 //
//     IMAGER: //
// Exposure: 1 //
// Gamma: 1 //
// Response: 105 //
// Saturation: 1 //
// Dithering: 0 //
// Enabled: 0 //
// Glare blur: 0 //
// 0:01 Octane kernel set: Direct Lighting //
// Octane: Scene file was successfully stored. //
// Result: D:/00_WORK/12_DSIII/test/sphere_orbx_test.orbx //
Hope this helps.
sphere_orbx_text.ma.txt
(329.23 KiB) Downloaded 344 times
fil3d
Render setting > Frame Range > Start frame 1, End frame 120.
Renderable Camera: Camera1.
Export orbx. Profit.
fil3d
Hello.
I have a question: time of the scene export in OctaneRender animation scene (orbx )
increases with geometrical pregression and it depends on quanity of frames in a scene.
For example, I have 200.000 polygones in my scene -- so it's ok to export only
10-100 frames, but when I try to export 200> it turns out just impossible.
It happens with all high-poly scenes.
longshoes
Thanks for the tip fil3d. Will try it out.
Return to “Autodesk Maya”
