OctaneRender® for Maya® 2.24.1 - 7.11 Win [OBSOLETE]
Locked
Maya® Version Requirements
This release will work with Maya® Versions 2013.5, 2014, 2015 and 2016 64-bit on MS Windows operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® License" priced at 199€
OCTANELIVE
  • Fixed bug: broken out-of-core functionality.
  • Fixed bug: swatch generation regression in some nodes.
  • Fixed the issue when Octane sun and lights got deleted by Maya's "Delete unused nodes" operation.
  • Minor fixes and improvements...
DOWNLOAD
OctaneRender for Maya 2.24.1 - 7.11 (12.2MB autoinstaller file)
OctaneRender for Maya 2.24.1 - 7.11 Demo (11.2MB autoinstaller file)
viewtopic.php?f=24&t=50202
Yours,
The OctaneRender™ Team.
blackshore
out-of-core function seems to still be broken.
Maya 2016+ ,Standalone: 2.24.1, 7.11 maya plugin.
Have anyone else managed to get it working?
jonathanhadley
I cant seem to get the octane lights Color Type set to Color and not Temperature, the toggle will change int the channel box but it has no affect on the image, and none of the Color Type settings appear in the attribute editor only the channel box.
I've checked the script editor and the commands are being made
setAttr "octaneLight1.ColorType" 0; - Temperature Mode
setAttr "octaneLight1.ColorType" 1; - Color Mode
But they have no effect on the light in the render.
itsallgoode9
This isn't specifically related to this version but when I hide geometry the IPR render doesn't reflect that until I restart the render. Doesn't matter if its a proxy or not.
RickToxik
Hi, octane maya does not seem to fully support boolean operations yet. Is this implementation planned for the plugin?
Jolbertoquini
Local DB doesn't work,
Hi Guys so when I export the Local DB works fine no issue I check all connection there and good at the standalone as I made on Maya but if I use to import back to Maya the setup is all wrong. Please any Idea attach the file orbx here and some screen shots
Dirty_Scrath.orbx
(81.48 KiB) Downloaded 215 times
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
Next version HERE.
Locked
Return to “Autodesk Maya”
