render erro
misi
Hi all,
I m having some issues with the render, I dont really understand why.
It looks random to. My render stops all the time after few frames, but when I restart is from that very same frame it render fine, goes forward, and stops at another frame.
Here is the link for the scene file, and I attached the log file as well.
http://we.tl/jTbsimMENQ
Thank you!
octane 2.23.2 150913 101604.log
(23.55 KiB) Downloaded 146 times
What's your gpu? How much free vram do you have while rendering?
misi
I got 2 titan black and one gtx 780 6gb.
Anytime I checked only 2gb of vram was used.
i'll let it rendered to see what happens.
misi
Thank you!
I reinstalled the whole system. I am going to give another go!
misi
I am having the same problem. The display driver stops and recovers , so I assume that could cause some problems. I use the 255.82 nvidia driver and I am having random display erro messages when I use octane.
Do you know about any nvidia driver related issues?
misi wrote:I am having the same problem. The display driver stops and recovers , so I assume that could cause some problems. I use the 255.82 nvidia driver and I am having random display erro messages when I use octane.
So should be a driver/gpu related issue. I hardly remember some posts about issues on some driver versions. You may try older whql driver.
misi
I installed the 344.75 version and test it.
Have you got anything useful from the log file?
misi wrote:I installed the 344.75 version and test it.
It show Cuda error as you see. It's not directly related with plugin and not transparent to understand the problems. Possibilities: out of vram, reaching the triangle limites, some errors on gpus.
First two not possible in your scene and with current gpus. So my idea is that about a problem on gpus.
misi
Problem with GPUs? Do you mean some hardware issue, or more like driver issue?
